Thunderbird
  • No replies
  • 1 view
First when I try to write an email I put the op name in the To: box but the contact list from my address book I imorted from my new outlook(I do not have 365)does not work -there is nothing. I need the simplest way to synchronize the address book with the To: when I send an email. 2 I'm confused about export and import. I always thought I import from something and then I export to something but it seems that Thunderbird commingles the two terms. I was trying to import from my outlook new to Thunderbird. Is it a matter of language or understanding? Thunderbird seems to work except for the above mentioned feature. Please explain? 5-29-25
First when I try to write an email I put the op name in the To: box but the contact list from my address book I imorted from my new outlook(I do not have 365)does not work -there is nothing. I need the simplest way to synchronize the address book with the '''To:''' when I send an email. 2 I'm confused about export and import. I always thought I import '''from''' something and then I export '''to '''something but it seems that Thunderbird commingles the two terms. I was trying to import from my outlook '''new''' to Thunderbird. Is it a matter of language or understanding? Thunderbird seems to work except for the above mentioned feature. Please explain? 5-29-25
